TwinTurbo.NET: Nissan 300ZX forum - Did things work well before the harness swap? If so,
jzack
on October 22, 2012 at 6:15 PM
Number 1 CYLINDER
posted by ZTom
on October 22, 2012 at 05:17 PM
would believe this issue may be due to that. Verify the ECU connector is properly seated. If all is good with that I'd continuity check the ECU to PTU connection for that cylinder and verify the harness wire is connected.....
Number 1 CYLINDER
ZTom
17:17:12 10/22/12
Did things work well before the harness swap? If so, -
jzack
18:15:29 10/22/12
Re: Did things work well before the harness swap? If so,
ZTom
19:15:28 10/22/12
PTU drives the coil packs - get's it firing signal from
jzack
19:26:54 10/22/12
Re: PTU drives the coil packs - get's it firing signal from
Medallion Man
06:32:56 10/23/12
CAS provides the ECU with the timing signal to fire the
jzack
09:22:58 10/23/12
PS - Just throwing this out there but since you have a
jzack
09:34:46 10/23/12
Re: PS - Just throwing this out there but since you have a
ZTom
11:08:14 10/23/12
This diagram should help - the online Z32 factory manual
jzack
12:56:48 10/23/12
Re: CAS provides the ECU with the timing signal to fire the
ZTom
21:17:29 10/23/12
sounds to me like your PTU is fried
Zvil
07:13:28 10/23/12
Test everything as shown in the FSM, make sure he coils have
Supermario680 (WI)
15:04:35 10/23/12
And its possible, but I would think unlikely. Grab a meter
Supermario680 (WI)
15:07:17 10/23/12
Re: And its possible, but I would think unlikely. Grab a meter
ZTom
10:41:15 10/24/12
